Installing MK4 injectors? Clips? NEED HELP FAST!!!
turbomk3
I am going to be installing the 550's out of the mk4 tt and i need to know if i need clips or not and what the clips are? are they the little electrical plug on the top of the injector? what is teh clip used for? thanks for the help
empera
Authorized Vendor
Philly.
i think i've asked this before....and i dun think that mk4 injectors will fit correctly in the 7m.
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
I'm pretty sure 2JZ-GTE injectors are side feed, the 7M-GTE uses top-feed injectors. 550cc injectors are a common mod, just not MKIV ones, because I don't think they fit.
(Unless only the JDM 2JZ-GTE was side feed and the USDM one is top-feed, but I'm pretty sure they are both side feed.)
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
oneandgone said:
JDM MKIV's use 440 cc injectors. All MKIV's use side feed injectors. Side feeds WILL NOT work on the 7M. BTW...side feeds are teh suck.
Yeah I knew JDM 2JZ's were 440cc's, and that they were side feed, just wasn't 100% sure on the USDM ones, (more like... 95% sure, hehe. :) I'm at work, so I can't look much up here -- I feel helpless ;))
gixxer750
2jzget comingsoon!
Mississippi
Wrong answer. I have a friend who has a 1993.5 mk4 non turbo automatic. He has a 2j-ge engine, and his car uses top feed 440 cc injectors, that happen to have the same part number as my stock injectors. The afm housing is also the same, although the electronics are not.
lagged
1991 1JZ
new rochelle
i am pretty sure that the fuel system in the non turbo mkiv is very different than the fuel system in the turbo mkiv, UNLIKE our cars where the ge and gte motors have an identical fuel set up with the exception of the injectors and a different stock fuel pressure.
so maybe the non turbo mkiv has top feed injectors, however it is a known fact that the turbo mkiv uses side feed which <insert previously stated answer here>
too lazy? which WONT WORK with our fuel rails.
Jeff Lange
Administrator
4,922
12
Sunnyvale, CA
jefflange.ca
The 2JZ-GE has a completely different fuel rail than the 2JZ-GTE, they're not the same and have different setups.
The 2JZ-GE does use the same type of AFM as the 7M-GTE though, the Lexus/550 mod is quite popular N/A-T 2JZ guys too. :)
Idealsupra
Orlando
www.tampabaysupras.com
ummm no RIGHT answer...considering we are talking about mkiv TT 550cc injectors... not NA MK4 injectors...
MK4 TT injectors WILL NOT WORK.....PERIOD.
turbomk3
well thanks i almost bought the injectors too so im glad and posted before i went and bought them! thanks guys!
gixxer750
2jzget comingsoon!
Mississippi
no, this is the post I was replying to. Therefore, I am correct.
