Installing CPS (not a timing Q)
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
I'm not the one that disassembled the head, so i don't know this: i get the CPS in, but there is space (like 2mm) between the cps and the head (same for the adjustment flange), that is occupied by the O-ring. is there supposed to be this space? will it go away when i tighten the adjustment bolt? wrong o-ring?
thanks guys!
Sawbladz
1,727
Oshawa, ON, CA
perhaps the gear itself did not mesh properly with the gear on the cam? Maybe try pulling the CPS out and slightly moving the gear?
flight doc89
Registered Murse
Apr 21, 2006
227
do i have to get this O-ring from toyota or will it come in one of those generic catch-all o-ring kits?
no pics, cant get drivers for camera phone (x64 ftl)
EDIT: the oring goes all the way to the base of the CPS, correct? not to any of the grooves?
Frank Rizzo
478
Fixing your girl's car
Yeah go to the dealer. It's like 80 cents.
And I know exactly what you are talking about. A new o-ring will be TIGHT..... Use a little elbow grease on her she'll slide right in. Don't try to close the gap by tightening, the gear might not be fully meshed on the cam and you might crack the CPS adjustment flange.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
jetjock;903496 said:
It's a standard metric O ring and goes in the groove. Just get it from the dealer. I use a gasket. End of leak story...forever.
So you are using a gasket in place of the O ring? That's how interpreted that, am I right?
jetjock
creepy-ass cracka
9,439
I still use the O ring for alignment but the gasket renders it superflorous for sealing purposes. I'm anal though. Just don't make it too thick and best to make it the outline of the entire surface. That way you'll still get proper gear meshing and won't load the hold down clamp.
How about something dumb like the old O ring still in head and that is why the new ring gets pushed up to the top? The O Ring should fit in the groove just above the upper gear. Like mentioned, put a little oil on the rubber so it doesn't get ripped when installing and it will go in easier (same idea as injector O ring instalation)
flight doc89
Registered Murse
Apr 21, 2006
227
oh, well that explains it. i put the oring at the base *lol*. maybe its .80 at autozone, but its $10 from Toyota (no joke)
flight doc89
Registered Murse
Apr 21, 2006
227
no need, now that i'm putting the new ring in the right spot, it IS the right ring that came with the kit (but i made a gasket for it just to be safe anyways :D )
Car is back together. just gotta replace the connector between 3000 pipe and throttle body, and i be driving again (after 6 months of withdrawal) (hopefully it will actually run!)
