injectors
dsm_tuner260
138
Fort Wayne, Indiana
do i have this correct.
i understand that the ge yellow plug injectors are low impedence and they already have the resistor pack. so since i have the yellow plug injectors i wont have to get the resistor pack to do the ge-t. i got what looks like a resistor pack on the wheel well with the fuel pump relay
8,898
If you try and swap the low impedance high flow injectors into a GE that was a low impedance, the pulse width from the ECU is different. This is why the Lex mod works. The AFM signals still match up with the expected fuel. It won't with running a 440 injector in a GE.
dsm_tuner260
138
Fort Wayne, Indiana
im doin the ge-t swap so im gettin the gte electronics and ecu and harness. i was just wondering bout bout the resistor on he fender that i already have as that being the same as the turbo
jetjock
creepy-ass cracka
9,439
1) The GE injectors are (iirc) high impedance
2) The GTE injectors are low impedance.
3) The GTE uses a resistor pack. It needs one because the injectors are low impedance (duh).
4) The fuel pump speed resistor pack you're referring to has nothing to do with injector operation.
