Injectors for my 1jz
935motorsports
San Diego, CA
They are oem injectors that are high flowed (bored out) or some other procedure to get more flow.
I'd suggest a simple set of US 550s on a 1J. That enough fuel for most of your needs.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
If you use US spec 550s, don't you need the resistor pack from a US spec 2JZ-GTE? The US spec ones are low impedance, and the 1JZ uses high impedance injectors.
