injector seating
duffer26
74
Colorado Springs CO
OK well i got my soup up and running but i have found a problem i need to go and redo the o-rings that i just did that and I'm getting a vac leak from the base of them so how do i do it the rite way the first time thanks do you put them in the head first then bolt the fuel rail to them or put them in the rail and install as a Assembly ?
any one got the part # for the gromets and o-rings from toyota ? thanks
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
90301-07001 - Upper
23291-41010 - Lower
And what do you mean you've got a vacuum leak on the injectors? I've found it easiest to put the new o-rings on the injector, insert the tops into the fuel rail first (use a little spit to lube the o-ring so it'll go in without pinching), then work in them into the head one at a time from the front to the back.
CRE
Oct 24, 2005
3,485
Denver, CO
Gotcha, they were probably dried up and had shrunken a bit. New gromets should take care of it.
