injector impedence question.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
hey guys, i know my 88 7mgte using a low impedence injector.
my question was i have recently picked up a set of RX7 550's. P/N : 195500 1370
they are the purple top injectors, as of now what i have read on the net about them are they are "high impedence"
i will ohm them out tomorrow to find out for sure though.
i though i remembered some people talking about 90-92 used high impedence?
or there was a way to use them in the earily modles by swaping parts?
if you guys & gals have any information for me it would be great! i would really love to break the 400whp mark, and im almost there at 375whp &335ft lbs & was running out of fuel on the stock injectors.
thanks again!
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
On my 88 I have used low impedence denso 550cc's, The part number is 195500-2020 they are the red tops that also came in rx-7's. Your stock injector drivers will not work properly with a high imp. inj.
HTH
Aaron
Pantaloon007
Permanent Ban
Apr 2, 2008
76
Vegas
Just for shits and giggles, does a toyota injector driver have just one low- and one high-impedance rating? Im sure there are different ohm readings within the high and low ranges, no? Otherwise you could use one from another model year that was high-impedance. AFAIK, you could use the hi-imp. driver if you needed it to run RC's or whatever and had a lo-imp to start with. Or vice versa.
Of course I could be wrong. And all I know about isfor MK1 MR2s. But knowing toyota, they did that somewhere else too
simpsons7s
Oct 9, 2005
253
Riverside, Ca.
I think that in order to change injector drivers you also have to change your ecu to control it, because the fuel map values wouldn't be the same.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
just found that 89+ n/a have high resistence injector's. as far as i know they still have resister pack's for the injector's so im going to hunt for one of those at the moment,
any one have more info please speak up!
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
http://www.rx7club.com/showthread.php?t=540798
i found some more info .
Just the clarify...
The low-impedence 1986 - 1987.5 FC turbo fuel injectors are *purple* brand new.
When faded, they look gray / tan.
The high-impedence 1987.5 - 1988 FC turbo fuel injectors are *red* brand new.
When faded, they look pink.
Both sets use the rectangular "Bosch-type" plug, but the keys are offset due to the difference impedences.
The low-impedence, early year ones are center keyed.
The high-impedence, later year ones are offset to the side.
-Ted
__________________
looks like i should be fine with these, but i'll still ohm them when i have a chance but looks like im going to buy injector clips.
