improper valve to cam lobe clearance?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
My engine has been ticking for a while now, and I've always known it was due to having improperly sized shims between the lash caps and cam lobes. I haven't been able to fix it, though, as the Supra is my one and only car, and daily driver.
Recently, the sound has gotten a lot worse, but it's only coming from the rear of the head. I believe it is from the lobes 11 and 12 (and possibly 9 and 10 as well) on the intake side, literally rubbing against the valve adjusting shims.
I made a video of it, it becomes more audible as I have the camera over the engine.
Please excuse the poor quality.
AJ'S 88NA
2,419
Florida
That sounds like a lot more than valve lash. Not right that the cam lobes are scored. They normally get worn, not scored. Did you notice anything laying around when you had the VC off? May have spit a spacer.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
The first thing I thought of when I heard the sound was "god I hope I didn't spit a shim". But when I checked, all shims were in place. I'll go back out and take it apart again to check again. Shouldn't take me more than 3 hours
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Pictures of cams. The head is disgusting, I know. PO was not very clean about anything with the car...
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
rayall01;1378945 said:
It might just be bad audio, but it sounds to me more like an exhaust manifold leak, than valve noise.
It's probably bad audio. In person, to me and my dad at least, it sounds like metal on metal contact
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
funky_monkey58;1379014 said:
Do you have a set of feeler gauges?
I do.
I think it might be as rayall suggested with the exhaust leak... I let the car warm up, and revved it a few times, and I had smoke coming from the back of the head. Possible EGR cooler gasket blowout, and the rattling I'm hearing could be the bolts vibrating from the turbulence...
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
take a piece of string or paper or zip tie and dangle it behind the motor and/or that general area. see if it moves. this may help you find the leak, if there is one. try revving the motor a little too.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Well I let the engine get up to operating temps and revved it up, exhaust was blowing from out behind the head. That's why I assume EGR cooler gasket. It would suck because I'd have to pull the engine to get at it... unless I can just torque the piss out of the bolts holding the plate on
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
DANGER WILL ROBINSON!!!! ....remember aluminum head and there is a gasket...if it is blown, then it needs replacing.......lol, you don't have to remove engine. just pull head off, and replace head gasket while you're at it and throw on a set of ARP head bolts.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I don't plan on keeping this engine in the car much longer. The engine has 237K miles on it. The valve stems leak, low compression, leaking rear main seal.
I meant super torque the bolts down as a temporary fix until I can get the engine back together. I'm just waiting on gaskets and helicoils.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
a complete gasket kit, oil pump, water pump, bearings, arps, timing belt, and some rings will save you money in long run. That will run you about 700 bucks. If you get a jdm engine, spend another 500+ dollars.....Even if you get a jdm/junk yard engine, i would still rebuild it. The engine you have now doesn't have rod knock, so that is better than NOT knowing, like on a jdm engine. you never know what you're gonna get. Just make sure all clearances are good and you have all machine work done.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I know all of this already. I'm saying that I have a usdm 7m-gte disassembled in my garage waiting for gaskets and helicoils.
I do not plan on keeping my 7m-ge in the car for the long run.
