IMPORTANT: Boxer's or boxer Brief's READ
What Kind of Undie's do you wear
  • Boxer's
    Votes: 21 70.0%
  • Boxer Brief's
    Votes: 9 30.0%
  • Total voters
    30
boost PSSH boost
SM's Welding Guru
Apr 4, 2005
465
Marshall, WI
Sometimes briefs and shorts, sometimes boxer briefs.
I wore boxers for a while, my testiclites would rub against my legs and chafe them. It got so bad I had to turn down getting laid once in a while. Baby powder takes care of the rash, just so you guys know...then you smell spring fresh, AND don't cringe every step you take. :biglaugh:
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I wore boxers until about 2 years ago, switched to Boxer briefs and will never look back. I don't get them really tight, just enough to keep everything in order, and I HATED how boxers would ride up my waist all the time, never had that problem with boxer briefs.
Fuzz420
Are U Here 2 take My Baby
My urologist told me boxers were better for your sperm count, as the testicles need to be few degrees cooler than the body to produce sperm. When you wear briefs your testicles are closer to the body heat and produce less sperm. So if your not worried about your sperm count briefs are for you. If your trying to have a child or you a testicular problem and as a result have lower sperm count boxers ftw.
JustAnotherVictim
Well lower sperm count is a plus since I don't want kids. :icon_bigg
