ignition problems
dallasupra90
dayton
ok so i have an 89 7mge and i have no clue what the problem is it kinda sounds like the problem other people are having called (heat soak) but a little different my car will crank over just fine but wont put out any spark so i pulled the ignighter and coil off and put them on a buddies car and it fired right up and didnt miss or anything so i checked the distributor, fusible links, and fuses all of it checked out so i put it all back together and tried again and the coil sparked off the shock mount but it will only do this when the battery is low and almost dead if i charge the battery and try it again ,no spark it done this about 4 times and i,m stumped so if anyone has help i would apprieciate it thanks
89Joe
POTATOES!!!!!!!!!!!!!!!!!
Jul 22, 2005
300
Missouri
Check the plug to the distributor. The wires right at the plug have been known to corrode over time.
