Gday all. Got some final news on this long saga of mine.
The rewiring solution I last mentioned only worked for two weeks then it was back to the same old problem. I was sure I had finally solved it.
I now have finally solved it and no longer have the problem at all!!!! very yay!
The cause of the problem was....
drum roll...
the MAIN RELAY!!!!
Yep!
I had a mate come over to help me nut out the problem. Its a hard problem to diagnose, because you only have that 10min window where the problem occurs to do your testing... not easy
I thought it was the wiring to the ECU because thats where everything pointed with the code 11, and in a way it was true, because the main relay was part of the circuit I rewired. I now think the reason it worked for two weeks is because I bumped the relay around enough when redoing the wiring that it made it work better!!!!
When we were testing things, I was explaining that i redid the wiring and mentioned the main relay was on the circuit, but I didn't think it was that because I had tested it as per the TSRM. But when my friend had a look at it he touched it and it was very hot, a sign of high resistance, which is a sign of bad circuitry/faulty component. He gave it a good shake and the car started up right away! Wow!
So, its been about a month and I have not experienced the problem at all! I've got a new relay from toyota and so it should last another 2009-1986.5=22.5 years, lol.
I feel like making a new post describing the problem and solution because if my relay just died and it is one of the oldest MKIII supras around, then surely later everyone else will be running into this problem, plus I live in Australia and the extreme weather here would have made my relay age faster.
I am surprised that no one on here suggested anything like checking the relay, it seems to obvious now, but I guess things always look like that in hindsight. Anyways, thats all folks.
