Question, My 1jz won't start. I'm getting a code 14 and want to check and see if I have spark by pulling a coil, connecting a plug and grounding it like the 2jz TSRM suggests, then cranking. Can I pull the fuel/efi fuse while doing this? I don't want to be dumping fuel into the motor. I know the ecu/computer cuts fuel when there is no IGF signal, but does it stop spark if there is no fuel? I assume no, but don't want my test to be worthless.
Also, can cracked coils alone cause a code 14? I fixed the cracks tonight with clear nail polish and will try again tomorrow.
