I have a 88 supra that Im attempting to wire up a 2jz-ge into right now but Im having some trouble with wiring up a few things, namely the igniter and coil. I have the one that came from the 2jz-ge and the original one from the 7mge. on the 7mge there was 1 plug that went to the igniter and then it had one coming out of it for the coil, easy enough. Well the 2jz igniter has 1 5pin harnis that attaches to it, so the questions I have are:
1) Where does the coil wire up to?
2) Can I use the 2jz igniter with the 7m coil, or should i go with the 7m coil and igniter?
3) if I can use the 2jz igniter with an after market coil?
(from left to right) 2jz igniter, aftermarket accel 140008 coil, stock 7m igniter and coil
