Idling problem
h20dies
12
Illinois
I reset timing totally and i got it to the point where it will idle a lot better but still dies on occasion. My coil pack grounds are not grounded but im confused on where to find the wires. _._
DeMoN2318
572
Arizona
Your TPS isnt cal'd and your coils pack isnt grounded...and your car isnt idling correctly? shocker
Fix the code 52, Cal the TPS, ground the coils...if it still doesnt idle then we can actually start to diagnose the problem.
Fix the obvious stuff first
h20dies
12
Illinois
Fixed them, it idles and drives good but stumbles every once in awhile and almost stalls now and it's slower then sh**.
DeMoN2318
572
Arizona
It's a GE (according to your profile)...it's not gonna be screaming fast.
Do you have an AFR gauge installed?
How are your spark plugs?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
CPS adjusted all the way to one side to get it to run? Maybe off a tooth. Double check. It will act as described and may not throw a code (didn't for me).
