Idle problem
1SLOMK3
219
Arizona
I have an 87 Supra Turbo. The 7M-GTE was rebuilt about 950 miles ago, It ran great and idle was perfect. Just recently I found a coolant leak on the hose from the throttle body to the heater core??? any way I replaced the hose and put a new gasket on the upper part of the intake manifold. Now when I start the car idle goes to about 500 rpm and then dies. Any Ideas?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
It's normal to have idle problems after a battery disconnect. It should normalize after ~15 minutes of run time.
8,900
Devin LeBlanc;1698959 said:
Normal? I have disconnected the battery on my supra 10 times and on several customers supras and never had any idling issues after at all....
Their cars weren't "supramania'd". I don't think it should take 15 minutes to relearn the idle speed position. Unless there is something wrong with the car.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Chances are you created a leak somewhere when you removed the manifold either from a gasket not sealing or forgetting to put a vacuum line back on. Double check all your vac lines and make sure nothing like a wire is caught between the manifold and the lower intake. Also make sure you plugged all your connectors back in properly.
CajunKenny
Nov 15, 2007
3,255
Washington
jetjock;1699031 said:
What Nick and Devin said. There's an enormous amount of misconception on this site about ECU learned values and how they work. The OP's car clearly has other problems.
Hmm…I’ve owned three Supras and worked on many others. None of them idled normal immediately after a battery disconnect. Some take longer than others. My current supra (91) doesn’t idle normal for 3-4 minutes. I must be doing something WAAAY wrong! ;)
And, for the record, I know better than to make a statement like that. I officially open myself up to lashings in the town square....
radiod
1,342
Abbotsford, BC
Ok, one thousand lashes to CajunKenny with a wet noodle.
I'm with Cy, check all your connectors and vacuum lines. For the heck of it check your codes, it might shed some light as to what's going on.
jetjock
creepy-ass cracka
9,439
Kenny: without getting into a lot of detail I'll make it simple: The closer learned values are to null, the closer they are to the default values used by the ECU after reset, the closer the engine will immediately run as it did prior to reset. That's how the car was when it left the factory and that's how it should be kept.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
That makes sense, but consider that the learned values prior to the reset were not close to default, wouldn't that affect the first start up?
Oct 11, 2005
3,822
27
Thousand Oaks, CA
There is a grand total of 16 bytes of stored data, and one of those bytes is used to tell the ECU that there is valid data in the other 15 bytes, so that is a total of 15 bytes for stored useful data. Some of those 15 bytes are used to store fault codes, there is even less learned! The target ISCV setting for idle with and w/o A/C is all that is saved. Also, target idle is a function of coolant temp, so if coolant is below 80C your idle will be high.
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks.
gsxr141
1,158
10
rochester
i hate to hijack a thread, but...........
i've had an intermittent idle/ stalling issue for a week now. today the car died and won't restart.
if anyone has an idea what might be wrong, please chime in.
thanks.................. kevin
1SLOMK3
219
Arizona
So while checking for lines that might not be hooked up and vacuum leaks I found this....
So I took off the manifold again and found that it goes here
What do these wires do and will this one being broken effect the idle at all?????
