Ok so I checked for codes don't have any. My car will start butidles like a 350 on steroids, if I hit the gas and hold it, it will miss but if I Rev it it wont miss until it idles. After it starts to warm up it gets better I can hold down the gas and it runs fine but idles high then low etc.. then after a bit it starts to come down on idle to where it should be but still misses but not near as bad. Any thoughts or suggestions would be appreciated. I checked the cps and tps and afm all seem to be fine. Could it be cause there is no air filter at the moment and no exhaust past the turbo elbow? Eh I'm just stumped. All the vaccim lines are new and hooked up right and I cant hear any leaks hissing or feel any, I even used carbon cleaner around the gaskets to see if there was a leak none found. Also I am running autolites and the miss is not slight it very noticeable.
