IC question
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Hi guys, I have a question regarding a Intercooler,
My friend is giving me his Greddy 3 row intercooler
with piping, can i fit this intercooler in my supra??
Can i use some of the piping? I'm thinking i have to
mod some of the pipes to fit, if any body has an idea
please chime in. Thanks Art. Oh i almost forgot, The
Intercooler is coming from a 95 MKIV with stock twins.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
U can use it but you will have to make ur own mounts for it and cut and do some modding on the piping to possably make it fit if its going on a 7M car. If its a 1JZ/2JZ swapped MK3 then I think the piping should fit right.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
MKIV piping is a little different than the MKIII with 1J. piping will be a little different, but you wont have to mod it too much to get it to work.
get that shit
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
A JZA80 IC in a JZA70? That an interesting idea :)
You will need to fabricate a custom mount and latch assembly (easy), but the piping fits almost perfectly.
Jostar
May 21, 2007
746
Chicago
WOW! that looks real good, I believe i can fabricate custom mounts, A little scared on the latch though. :(
annoyingrob
Boosted member
Jul 5, 2006
2,304
I'll snap some more pictures when I get home. I'm at work right now. This is the only picture I have on the server. It's a steel L beam mounted across the stock IC mounting locations. It then has tabs welded onto it to support the IC, the hood latch, and the stock PS cooler. That's an additional PS cooler ontop of it all.
Here's how high up the IC actually sits.
