I really dont know what to do here
rasmussenbc
Gig Harbor, WA
update for those who dont know:
Car was overheating and losing coolant, so I fixed a monkey coolant hose job the previous owner did, now no fluid leaks
engine doesnt get as hot (still too hot) but now no heat
i figured the previous owner did the weird hose job as a cheap way to bypass a clogged heater core some way and still have heat
heater valve working properly
REPLACED HEATER CORE, STILL NO HEAT
that last part really ticked me off
the overheating is a secondary issue as far as Im concerned. it stays below 200 almost always. I just want my friggin heat back
help appreciated, thanks
mkiiibro
26
Detroit
Are you sure the valve is working properly?
Sometimes they may look like they are working, when in reality they are not. If i were you i would take the valve off the vehicle and inspect it to see if it moves freely, if it puts up much fuss, just take a piece of pipe and use it to bypass that valve altogether.
Thats about the only other thing that i can think of, happened on my car and my brothers as well; and both times this resolved our "no heat" problem"
powodzenia,
phil
gaboonviper85
3,236
Northeast Philly
if you could get pictures to show us exactly what you did then that would help alot! obviously no coolant is reaching the heater core so youre not gonna get heat.
nesupra87
4
Nebraska
Might as well bite the bullet and do the BHG fix. It will only get worse the more you drive it and never get better on it's own. I kept hoping mine would "fix itself", it just got worse.
arknotts
formerly ark86
Jan 9, 2008
461
Ohio
Why jump to conclusions? From his explanation it sounds like he was leaking coolant not burning coolant and fixing the hoses helped.
rasmussenbc: as gaboon said, pictures are worth a thousand words here. Also, compare your hose routing to the diagram in the TSRM:
rasmussenbc
Gig Harbor, WA
yeah I followed the TSRM exactly. It looks just like that now. It pretty much solved my overheat/coolant loss problem, but caused my no heat problem.
I'll try to dig up some pics of the old hose set up, but thats really the only thing that will show you guys anything
