i need help with questions
big yoggz
ok so im doing a 1jz swap and just for the record i strongly suggest to anyone not to buy stuff from tiger Japanese!!!! they are FUCKEN RETARDS!!!
anyways well i got a 1jz and asked for a supra but they send me a 1jz from a soarer.
my problem is that i got the supra brackets for the motor mounts and the one of the bracket dont match up...
shouldn't it still bolt up no matter what ????
does anyone know???
big yoggz
Bigzavs;1151990 said:
explain how it doesnt match up
pics would help as well
only one of the brackets fit
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
they both fit, if they didnt, then 3/4s of the 1J/2J swaps on here are magical
on the drivers side it fits no problem
on the pass side, you will have to move the mount back one set of holes for it to work
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
its true, i used a soarer in my supra. i forgot which side it is that you have to move the mount back alittle, i think its the side under the intake manifold. just check n try it
sctwinturbo
77
new jersey
the intake side under the intake manifold
i got the soarer engine in my supra also
theres a fuel damper in the way for the BIC mounts
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
actually i didnt mean that as a joke, when doing the swap on my friends car and on mine, the mounts on the pass side of the motor had to be moved back one set of holes, just ask gotturbos? about it, pulling a mount off while the motor is 3/4s of the way in the car with the turbo system on is no fun.
and hes using stock JZA70 mount brackets that he had not removed from the motor before hand
