I bought an 87 supra about 4 months ago with a BHG so i have slowly been fixing it, by getting a cometic mhg, getting the head machined a bit, putting in arp head studs, and got it all back together but it still has an idle problem it had before (Although i'm not burning through coolant anymore which is good). It surges and kind of chugs I know the timing is perfect because i triple checked myself. The car originally had the egr valve bypassed, but there was one in the trunk of the car so i put it on when i put it back together because I need to be able to pass emissions. I do know that there is an intake leak now because you can hear it whistle or whine (near the EGR valve area) when you rev the engine. could this be a bad egr valve that came with the car? is there a way to test it? my only guess as to the reason why it is running rough is because of this leak. Any thoughts or ideas? or anyone in Utah that would be able to give me a hand with it? I'm to the point that i am running out of ideas and may just turn my car over to a shop to fix it but i can't find any that seem to be real confident on the 7mgte engines.
