Hydrofan res relocation help
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
I need to re-route the lines for the hydro fan for my new setup. What is a suitable material hose to use? Can I use regular coolant line? These are the lines coming off the cooler. I'm not sure what temp they get up to or what pressures they see. Braided ss is NOT an option. Any help? Thanks everyone.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
is it the low pressure line you are wanting to replace or the high pressure line
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
For what its worth, My low pressure line is regular heater hose and it seems at though it is sweating fluid after the car gets up to temp. I need to find something more durable.
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Not sure, its the line off the res to the pump and from the cooler to the res. I've never messed with this before.
tlo86
Jul 24, 2005
3,914
Colorado
does it look like something you can easily pull off and replace with another hose or is it something that bolts in and is durable like it is holding a lot of pressure (think power steering like from the pump to the rack is the high pressure line, from the rack to the reservoir and from the reservoir to the pump is low) you'll need a high pressure line if thats the case.. and braided might be the best option..
i think driftmotion has one...
tlo86
Jul 24, 2005
3,914
Colorado
good idea to find something else i did that as a temp thing on my power steering
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Its the lines that fit over the ends of the hard lines and have squeeze clamps at the ends. I'm going to see if hydraulic line will work. I don't see any reason why it wouldn't.
tlo86
Jul 24, 2005
3,914
Colorado
sounds like a low pressure line you can probably use anything for
