How to tell if I have a turbo automatic transmission
Drake69
Enjoyin' mah ride...
Aug 24, 2009
648
Richmond, Virginia, United States
Every tranny I've ever looked at usually has a stamped code somewhere on the bell that helps to ID the type, even if it had a label on it somewhere. If it isn't visible on the outside, there always opening it up.
And IJ, with the horses you're planning on putting down, I can only imagine how much that tranny's gonna see torture. :aigo:
Ohh well, all in the name of science... :biglaugh:
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
I think if anyone can break it, its Ian. I also think if anyone can make something work, its Ian.
Ian The PCS is whats letting you run a Shift ignition cut right? Its not something i could do with the SSv4?
MK3pizzadriver;1503397 said:
Shouldn't there be numbers stamped on the case somewhere, not just a "sticker" indicating which car it came out of?(theoretically)
Dude, it's "through" lol
There's a small data plate riveted to the case.
I don't run a lot of HP it's more the torque I'm concerned about.
You could possibly do it with a couple of diodes and some way to signal a change of state using the SSv4 but yes the PCS has a shift cut channel.
spell check said it was correct. i dont have the best grammar so fire fox helps.
