I want to remove the front wheel axle hubs, to unbolt the brake dust shields so I can trim them properly for my big brake upgrade. The TSRM says I am supposed to remove the whole steering knuckle to disassemble the hub from the knuckle.
Question is - if I disconnect the tie rod end, rotate the knuckle around so I can remove the nut that holds the hub in the bearing asembly, will the axle hub slide right out or does it need to be pressed out? Input from anyone who has taken this apart themselves would be appreciated.
Thanks
Vic
Thanks
Vic
