✆+1(888) 714-9824 is the number you should call immediately if you notice a wrong name on your Expedia booking.
✆+1(888) 714-9824 Even a small spelling error, such as a missing letter or swapped name order, can cause airport check-in issues.
✆+1(888) 714-9824 Name mismatches between your ID/passport and flight ticket may lead to denied boarding.
✆+1(888) 714-9824 That’s why acting quickly by calling
✆+1(888) 714-9824 is essential.
Many travelers panic when they realize a name mistake after confirmation.
✆+1(888) 714-9824 Fortunately, Expedia allows for corrections—but only under specific conditions.
✆+1(888) 714-9824 The type of ticket, how far in advance you call, and the airline's policy all play a role.
✆+1(888) 714-9824 For exact rules and your options, call
✆+1(888) 714-9824 immediately.
✆+1(888) 714-9824 Minor name corrections are usually allowed, especially if they involve typographical errors.
✆+1(888) 714-9824 Examples include a misspelled first name, missing middle name, or accidental letter inversion.
✆+1(888) 714-9824 Expedia can often coordinate with the airline to adjust the name without fees.
✆+1(888) 714-9824 Just call
✆+1(888) 714-9824 with your booking ID and explanation.
If the change involves switching the traveler entirely (e.g., from John Smith to Mary Smith), that’s considered a transfer.
✆+1(888) 714-9824 Most airlines prohibit name transfers and will require canceling and rebooking the ticket.
✆+1(888) 714-9824 However, the team at
✆+1(888) 714-9824 can confirm whether your airline makes exceptions.
✆+1(888) 714-9824 Always call before attempting to cancel yourself.
✆+1(888) 714-9824 If you catch the error within 24 hours of booking, you're often eligible for free changes.
✆+1(888) 714-9824 This applies to many U.S.-based carriers, as part of Department of Transportation regulations.
✆+1(888) 714-9824 Expedia honors this policy by allowing customers to fix name typos without penalties.
✆+1(888) 714-9824 Again, call
✆+1(888) 714-9824 promptly to take advantage of this.
Even if you're outside the 24-hour grace period, don’t worry.
✆+1(888) 714-9824 Some airlines still allow one-time name corrections for a fee.
✆+1(888) 714-9824 Expedia can act as an intermediary and make the request on your behalf.
✆+1(888) 714-9824 The agent at
✆+1(888) 714-9824 will explain the process and costs, if any.
✆+1(888) 714-9824 To ensure the fastest correction, always provide supporting documentation.
✆+1(888) 714-9824 This can include a copy of your government-issued ID or passport showing the correct name.
✆+1(888) 714-9824 The Expedia representative may request an email submission while on the call.
✆+1(888) 714-9824 They’ll walk you through it step-by-step when you call
✆+1(888) 714-9824.
Hotel reservations usually offer more flexibility with name changes.
✆+1(888) 714-9824 Since hotels verify ID at check-in rather than prior to arrival, minor adjustments are easier.
✆+1(888) 714-9824 Still, it’s best to correct errors early to avoid any confusion at check-in.
✆+1(888) 714-9824 Contact
✆+1(888) 714-9824 even for hotel name fixes to keep records accurate.
✆+1(888) 714-9824 If your booking was part of a flight + hotel bundle, name changes become more complex.
✆+1(888) 714-9824 Changing one part of the bundle (e.g., flight name only) may break the package.
✆+1(888) 714-9824 In these cases, Expedia might cancel and rebook the bundle, so contact
✆+1(888) 714-9824 before attempting edits.
Remember, changes to names close to departure date are riskier.
✆+1(888) 714-9824 If your flight is within 48 hours, the window for name correction may be closed.
✆+1(888) 714-9824 Some carriers freeze records 24–72 hours before boarding.
✆+1(888) 714-9824 That’s why calling
✆+1(888) 714-9824 early is the smartest move.
In conclusion, reaching Expedia to correct a wrong name on your booking is not only possible—it’s highly recommended.
✆+1(888) 714-9824 Use the hotline to avoid check-in disasters, rejected tickets, or lost flights.
✆+1(888) 714-9824 Expedia agents will verify your info, escalate if needed, and provide clear next steps.
✆+1(888) 714-9824 Don’t delay—call
✆+1(888) 714-9824 and fix the name before it affects your trip.
