How to question
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
With the motor and transmission out, is there anyway to provide power to the cab of the car, i.e. to roll up/down the windows?
gtsfirefighter
Sep 26, 2006
2,966
DFW
dgilman360 said:
letme guess you left the windows down????
Let me just say one is not up all the way, it's down just a crack.
MK3Brent The engine wiring harness is still in the car.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Yeah, as long as the harness is still there.
The reason I asked, is that so many just unhook the 3 connectors from the ECU and ABS comp. then pull the harness out with the engine.
you'll need to touch or mount the main ground from the battery to the chassis (as it's usually mounted to the block)
might work regardless as there is a smaller ground wire, but I wouldn't want to run too much through it...
yankiwi
221
DFW
Hey Ken,
I had the same problem once, forgot to wind the window up. I just hooked the battery back up, turned the key and wound it up. Nothing fried!!! The batt was still grounded on the smaller wire, and the window motor is on the body harness, not the motor harness.
Craig.
