How to protect my bare block???
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
How can I protect the side of my block where the manifold and oil lines normally go? It will be under the hood but NOT in a garage. I don't want to risk rusting or anything getting in. What should I do until I get my new manifold? This is my temp fix when I removed it.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
My uncle alway put his motors that were going to sit for a while in a thick garbage bag and sprayed oil all over it.
But, since this is still in the car, I'd just use some duct tape to pug the holes, and maybe put a little oil in the ports to keep them moist.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
trash bag and wd40 is what i've done in the past, not sure if it's right for your case or not
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Its not going to sit like this long, no more than a month or 2 max, but I don't want to take any chances since its a clean machined surface that doesn't normally get exposed.
