How to Install the Titan Motorsports Harness Bar
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
No instructions??? I made one that bolts into the original seatbelt bolt holes and curves down and back. I works like it should.
MA70witBoost
Registered Drifter
no sir... thats what i need...
Thats the only picture i've found and i know the main part goes to where the seatbelts go but im not sure where the two verticle stabilizers go.
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
Just put them on and move them around until you find the correct spot. Most likely on the side where the seatbelt roller hooks up or the floor board somewhere.
MA70witBoost
Registered Drifter
no, thats not my car... so that particular push start isn't mine. Mine is hidden :D I covered all the panels in the car w/ dynamat so i can't see any of the original holes in the car. there is also no screw that comes w/ the vertical stabilizers... just the eyelet for the bolt to go through... im thinking bout just taking them off and leaving the horizontal bar.
Turbo Drifter
534
Surrey, BC Canada
Do not run that bar with out the vertical bars, those harness bars look like a death trap as it is. I would say that the vertical bard bolt into the stock lower belt spots with the bolts that held the lower belts in place that why there was no hardware.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
This was actually a little tough to photograph; but, let me know if you need a different angle or what not...
Sorry if this is too late by the way.
OneJArpus
2,798
it bolts to where the stock seatbelt bolts too at the bottom. was your stock seatbelt on when you put dynomat on? If so you should still see it, if not start poking around and hopefully go through the dynomat then take off what you need to bolt it in.
MA70witBoost
Registered Drifter
No, It wasn't. Someone had cut the driver side seatbelt. I got another one but it wouldn't retract so i figured screw it, id go 4 Point. I've felt around to see if i notice where the bolt might have gone through but yeah, the dynamat is there so I have no clue at the moment.:3d_frown:
