How To: IdealSupra's Famous Foglight Rewire
Status
Not open for further replies.
Idealsupra
Orlando
www.tampabaysupras.com
I took the SOGI rewire and changed it a bit to add more lighting options...
Jayson's Foglight Rewire
SKILL: Beginner
TOOLS: Wire Cutters, Wire Strippers, Electrical Tape , Phillips Screwdriver
PARTS: Wire, Some form of connector, Inline (Combination) Fuse
1) Remove screw underneath switch panel. Pull switch panel away from dash to reveal the fog light switch and defroster switch and whatnot.
2) Cut White WITH Black stripe wire on the DEFROSTER switch...leaving enough room on both sides to strip it to put back together.
3) Cut Red WITH Green Stripe wire on back of FOG LIGHT switch. Leave Enough slack from switch to strip and splice. Tape off the other end going into the dash.
4) Splice together the red WITH green stripe wire coming from FOG LIGHT switch AND the TWO ends of the white WITH black stripe that you cut on the defroster switch. This creates a seperate ground for the Fog light switch.
5) Tape up splice and put switch panel back into the dash.
6) Pull left kick panel and lower steering column (the part with the air vent) off.
7) Locate the Fog Light Relay. Located to the left of the junction box above and its facing towards the engine. Its kinda in no mans land. (Use TSRM and/or EWD to help locate it.)
8) Pull the connector off the back of it. Locate the Red WITH black stripe wire. Give the wire as much slack as possible off the connector and cut it.
9) Tape off the wire going into the dash and strip the wire coming from the connector.
10) If neccessary add an extension wire so that the red WITH black stripe wire reaches the Junction block by the fuse area. Or to at least about 3 inches from it as the inline fuse will make up for that with that wire.
11) Put the fuses in the inline fuse and attach the wire coming off it to the red WITH black stripe wire coming from the relay connector.
12) Choose a constant 12v fuse to place the Inline fuse. I chose the Cig Lighter fuse because i never use it and i have other things coming off my IGN fuse. You can use the IGN fuse if you would like. As long as its a constant 12v when the keys in the on position. Not sure? Use a test light or voltmeter to find out.
13) Plug Inline fuse into chosen fuse location.
14) Test your work. You should now be able to turn JUST your fog lights on without anything else being n. Key in the on position and you have your fog lights at your mercy
15) Replace panels and enjoy your new fog light rewire.
NOTE: An inline fuse IS NOT neccessary. Its just the best way to do it. You always have the option of wrapping the wire around the fuse leg but the inline fuse is much better and cleaner.
ANOTHER NOTE: The inline fuse mentioned will work...however it has come to my attention that what i used was actually a COMBINATION fuse. they are different.
FINALLY A PICTORIAL:
http://gallery.sanitylapse.com/v/supra/thumbnails.php?album=66
Big thanks to CWAPFACE for taking pics while doing this mod on his own car.
Idealsupra
Orlando
cwapface said:
excellent, i'm doing it this weekend. I'll take a million pics if you want to make it a complete "for dummies" mod :D
actually ive been meaning to do my buddies car rewire...and take pics of each step...if you wouldnt mind take each step i wrote down and taking a pic of it...from tool gathering to what the combination fuse looks like (a lot of people ask me that) to each step and finding the relay etc... and send them to me and i can host and put them in the main post...
that would be AWESOME! thanks!
cwapface
Supernerd
Eugene, OR
www.dylanwiggins.com
it ain't nuttin but a thang, i'll hook it up no problem
empera
Authorized Vendor
Philly.
88turboma71 said:
excellent mod im going to try it out as soon as my supra is back together
lol alot of us are gonna do this after we get our supra back together...;)
Idealsupra
Orlando
cwapface said:
Ok here it is, my step by step pictoral of IdealSupra's fog light rewire. Hopefully this will help all the other n00bs out there :)
awesome job man....im gonna link off that site and put the pics in the first post...if thats gonna kill your bandwidth let me know and ill save and host them myself ;)
also that inline fuse will work...however what i used was a combination fuse...its a little cleaner...i guess ill have to take apic of it :D
thanks again!
isnms
United States of America
Oklahoma
i80.photobucket.com
cwapface - do one more pic with the high beam, the fogs stay on :) try that stock. although it may not be very evident that's what the picture's of.
Oh, nice job on the docuphotos.
Arther3
Remember SOGI? I do
Starkville, MS
i did this mod over a year ago, i did not use the inline fuse and i also did not ground the foglight switch on the defroster ground, i ran a seperate ground to the dash frame... didnt think to try a ground from another switch.
americanjebus
Mr. Evergreen
wa.
all is crystal clear cept step 10 wit hte relay to the cig lighter fuse spot how you hook that in there does that thing just plug in like a fuse. and will cig lighter still work, i use like 2 things from cig lighter at a time will that overload that thing just an explanation of what step 10 is doing not how its done.thnx and btw those pics creep me out cus i have same tools like litteraly identical, that car is same color inand out as mine so its like you took pics in my car. i dunno its creepy.
SupraMario
I think it was the google
The Farm
i have control over my fogs. i can turn them on and off and my 87 NA is stock. was this an option on the pre 89s?
Status
