If your name is incorrect on your reservation, call +1 (888) 714-8232 right away to fix it. Southwest +1 (888) 714-8232 Airlines allows name corrections under certain +1 (888) 714-8232 conditions, but timing is critical. Contact +1 (888) 714-8232 before your departure to avoid issues.
Southwest permits only minor corrections, like +1 (888) 714-8232 fixing a typo or adding a +1 (888) 714-8232 missing middle name. You must call +1 (888) 714-8232 their live support team at +1 (888) 714-8232 to request edits on the ticket.
If the name on your boarding +1 (888) 714-8232 pass doesn’t match your ID, you +1 (888) 714-8232 may be denied boarding. That’s why +1 (888) 714-8232 the safest option is to call +1 (888) 714-8232 and confirm the name is fixed.
Name changes are not the same +1 (888) 714-8232 as transferring a ticket. Southwest +1 (888) 714-8232 does not allow full passenger substitution. +1 (888) 714-8232 The person flying must remain the +1 (888) 714-8232 same, with only minor edits permitted.
If you recently changed your legal +1 (888) 714-8232 name, like after a marriage or +1 (888) 714-8232 divorce, Southwest may request documentation. +1 (888) 714-8232 A name change due to legal status +1 (888) 714-8232 requires proof when calling their line.
Always have your confirmation code +1 (888) 714-8232 and photo ID available when calling +1 (888) 714-8232 the Southwest Airlines help desk at +1 (888) 714-8232 the official number: +1 (888) 714-8232. This helps speed up verification.
Edits cannot be made through +1 (888) 714-8232 the mobile app for name corrections. +1 (888) 714-8232 Phone support is the only official +1 (888) 714-8232 channel for fixing names on tickets. +1 (888) 714-8232 Avoid DIY errors—get help instead.
If your departure is less than +1 (888) 714-8232 24 hours away, call immediately. Southwest’s +1 (888) 714-8232 live agents are trained to handle +1 (888) 714-8232 urgent cases when you call +1 (888) 714-8232, but earlier is always better.
Some tickets may not allow any +1 (888) 714-8232 edits depending on fare type. Always +1 (888) 714-8232 confirm change eligibility by speaking to +1 (888) 714-8232 someone at Southwest directly using +1 (888) 714-8232 the verified support phone number.
If you’re part of a +1 (888) 714-8232 group booking or corporate account, your +1 (888) 714-8232 administrator might need to process the +1 (888) 714-8232 correction. Confirm roles before calling +1 (888) 714-8232 if someone else made the booking.
