how to adjust lex v8 afm
chevyguyjoe
55
Ft. Madison, IA
On the housing, there is a round metal plug that needs to be removed. Behind it there is a screw. To make the mixture richer, turn the screw in. The idle mixture is not as important as the mixture at wide open throttle. Adjusting the afm screw will change the mixture at all throttle positions and rpm's. Adjust for the WOT mixture. Did you put 550cc injectors in?
