How NOT to hook up a MBCV
MKIIINA
Destroyer of Turbos
Plano, TX
yea thats for the Z cars. they have a a different setup because its a twin turbo system and they need to balance out the pressures i would imagine.
you can make it work with a slightly different hookup:
1. line from pressure source on the compressor cover, run this directly to the boost controller .
2. the line that says it should be to the atmosphere should be run from the boost controller to the actuator.
this is how 90% of MBC are hooked up. im not 100% sure if it will work exactly with that one so test it and report back!
holdbrooks
114
Alaslama
That way works too but it is just making a boost leak. we ghettoed a similar setup on the dyno with a few people, but yes that would be for a twin setup to keep both sides the same.
OneJoeZee
Retired Post Whore
aboard the Argama
It's called jew boost. (bleeder T)
BTW, my turbos aren't hooked up to the boost controller like that... It's just the same as one turbo, except the turbo turbos are T'd together. That's all.
