How much do you think this is worth?
7mturbo
28
The sticks.
blue/black
<br>
5 speed
<br>
clean title + key
<br>
156k on cluster
<br>
7mgte
<br>
<br>
comes with stock - turbo/manifold(not blown), radiator, intercooler/piping, intake, power steering pump, exhaust, and rear stock wheels that are not in the pictures. also has heated or aftermarket springs. can't tell but sits low.
<br>
<br>
looks kind of bad right now just because it is jacked up and such...
dash is apart because i was going to swap the cluster with mine so i could have the stock volt meter and go aftermarket boost gauge, but i changed my mind..
<br>
<br>
have blinkers and side markers. just started to remove the bumper when we towed it home but gave up being our house was close anyways..
no damage was done when towed, used tow strap. same reason one headlight is up..
<br>
<br>
extra head + some pieces in back.
<br>
<br>
has w58 tranny for shorter gears(assuming). also has legit short shifter(no idea what type, but don't need since i'm using the r158).
<br>
<br>
will need - ecu, alternator, wiring harness(have one with a few missing plugs to go with), timing belt/pulley, water pump, cam position sensor, alternator and a few small things i'm probably forgetting..
<br>
originally purchased a couple months ago for the wiring harness + few extras to finish my car.
<br>
<br>
will need a trailer or tow bar because i took the master cylinder to replace mine. the brakes worked great when we towed it.
this is the only damage besides the spray paint coming off in areas
---------- Post added at 01:41 AM ---------- Previous post was at 01:37 AM ----------
how much now? and would it make that big of a difference putting all the stuff back on? i listed for $600.. was that fair?
the back wheels are in a set for $200 on the side. 235/45/17 on back, 215/40/17 on front with almost new performance tires..
Athena
Rawr
Jun 22, 2009
154
Raleigh, NC
just an fyi, you don't need line breaks in your post, they are making it hard to read your post at 5 in the morning XD
It's worth whatever the next guy is willing to pay for it.
Since I don't know where your located, assuming you were local, and I was going off of pics only, I'd offer a 500-800 to ya.
MKIIINA
Destroyer of Turbos
Plano, TX
id try and source some parts and get it up and running. 1600 or so as a runner (even if its not running all that well) is alot better than the 600 or so id offer as it sits now. heck even matching wheels will make life better as right now the mismatched set are taking away from it imho (try and find 2 replacements... big pita)
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
yea agreed get it running or put it all together you could probably sell it for 1500+....
it doesnt look like that bad of shape....just get her running and sell her
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
even running I'd offer $1000 at MOST. The exterior is the best part. The interior is worn to hell, the engine bay is super dirty...
With condition it's currently in, I'd personally offer 4-500.
7mturbo
28
The sticks.
yeah it looks bad just because im too lazy to put the interior back together. i have the stockies for it. ill just put everything back and retake the pics..
7mturbo
28
The sticks.
nah, sorry. the more parts it loses, the tougher it will be to sell. and a short shifter i think is the only thing that fits with the w58 tranny, since it is shorter and sits a little more forward on the 7mgte, but i could be wrong..this is in washington if anybody is interested.
Athena
Rawr
Jun 22, 2009
154
Raleigh, NC
It seems the consensus here is that as is, around 500-800. I"m not saying you can't do better, just an observation. Therefore, I would either get it in the best shape you can with hard work, get it running and I bet your looking at 1500. Or part it out. You already have some eying things they want, even I see some things I would take. Just giving my cents. (Non-refundable)XD
