how much boost to run?
mcammarn
matt
Feb 24, 2012
668
olympia wa
so im kind of scared on where i should set my boost to.
i have not put my rebuilt motor back into my mk3 yet.
so it has 0 miles on it thus far.
also it has a compostie hg not mhg.
whats safe to run for break-in period and what should be safe for after with running a composite?
list of mods are to include:
hks evc6
hks type 1 turbo timer
apexi intake
upper i/c piping
lex afm
560cc inj
afpr
wideband
3in elbow back exhaust
57trim ct26
mishimoto radiator
arp head bolts
act stage 3 pressure plate with full face disc
Turbo Habanero
4,229
Tucson,AZ
For break in I would leave it at wastegate pressure.
Then after turn it up to what your fuel/turbo/tune can handle.
So 12-13psi for stock fuel pump.
Turbo Habanero
4,229
Tucson,AZ
IndigoMKII;1895121 said:
Not for a 57 trim I wouldn't.
Stock pump will be fine because he has a afpr and a wide band as a fail safe.
So @ 12psi if he's not leaning out then he's fine and if its showing signs of lean then up the fuel pressure a little.
The stock pump should be able to handle this unless its dying out which the wide and will also show.
He might not be on a stock 20+ year old pump maybe a stock replacement who knows but I still think a good stock pump will flow enough.
The ct26 57trim really doesn't flow all that much it's something like 48lbs/min if I recall correctly so at 12psi doesn't take much fuel as something like a 60-1 which flows 59lbs/min or even a bigger turbo then that so he should be fine.
