How much boost can a stock 7M-GE take?
Southsidezsupra
7
Jamaica Queens
hello everyone .. i was wondering does any know how much boost a 7M-GE engine can take... ? anyone with a NA-T Can help me out a lil ..with some trial and error expeiriences?
HommerSimpson
1,067
New Smyrna Beach Florida
need more info.. like how many miles on motor.. factory head gasket ?
If it has 80k miles on it and its a grafite gasket... dont turn boost up.... you will have a bhg in no time...
iceberg319
vvti, what?
Apr 6, 2005
328
NJ
depends on the condition of the motor......but from my experience, i have a pretty low mileage 7MGE....i bough it rebuilt/remanufactured and drove NA for a bit then decided to slap on a turbo with associated electronics/fuel....been boosting 12-13 psi for the past few years on arps and oem headgasket and it still seems to be fine.
lookin to go big turbo in the summer tho
Southsidezsupra
7
Jamaica Queens
If it has 80k miles on it and its a grafite gasket... dont turn boost up.... you will have a bhg in no time...[/QUOTE
i just put in the the metal HKS headgasket along with ARP Bolts(both 2 weeks old ) and it has 102,000 miles ...
Southsidezsupra
7
Jamaica Queens
Thats a good set up .. the engine has 102,000 miles and i just put in the HKS metal head gasket along with the ARP bolts ...
Doward
4,245
Alachua, FL
With no work on the head or block? Were both checked for absolute straightness?
Do not be surprised if you get a leak or two in that gasket.
gofastgeorge
944
Texas
If you mean completely stock, with NA pistons,
I would say little if any........:nono:
You will need low compression pistons & MHG at least !
I agree 100% with the fart in the throttle body comment. :naughty:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Cripes, here we go again.
Anyone telling you how much 'boost' you can push through your engine is outright guessing.
Especially when nobody has asked you things like what turbo, intercooler, IC pipes, IC pipe routing, headwork, fuel injector size, fuel pump type, fuel type, ambient temps in your area, ... I could keep asking for RELEVANT factors here all day.
What you should be asking is how much horsepower your engine is good for, and you should be telling people everything you possibly can about your planned setup and the environment you are going to run it in.
THEN you should take their numbers with a massive load of salt, take it to a local dyno shop, strap it down, and keep turning up the boost while monitoring your air fuel ratio, exhaust gas temperature, AND listening for knock with a set of electric ears. When the EGTs get to high, you start to hear knock, or your AFR starts to get lean, you need to stop, back it off a bit, do a final run to see where your power levels are, and then compare that to what the guys here predicted.
626na
143
cali
how much did it cost you?
