How many mm to shim wastegate?
Alec
SP Tuned
Apr 6, 2009
712
Illinois
So I have everything apart cause I'm changing plugs/wires and valve cover gaskets and thought might aswell shim the wastegate. I have various sized washers and was wondering how many mm to shim it. I don't want any more than 8 psi.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
You're just going to have to put in a washer and try it. Depending on how weak your wastegate has gotten over the years, you may need anything from a very small washer to a rather large bunch of them.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Well, right now I'm pushing around 6-7 psi on the factory boost gauge.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
First, the factory boost gauge is about as accurate as a government sponsored census.
Just throw a couple extras in there, bolt it back together, and give it a go. You're probably going to have to mess with it a few times before you get it where you want it.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Well, I also have a POS aftermarket ebay boost gauge that isn't hooked up. I'm not going to shim it any more that 3mm. So I'm wondering if I should shim it 1mm, 2mm, or 3mm?
Alec
SP Tuned
Apr 6, 2009
712
Illinois
nightrider760;1383996 said:
do 4 washers for about 11 to 12 psi but again an accurate boost gauge its needed
How many mm is that? Washers come in all different thicknesses.
nightrider760
219
escondido , tijuana
just do regular washers from a hardware store and you will also have to but new bolts about a 1/4 inch longer than the stock ones.
To make it easier on you will have to glue them washers together with some super gule before installing them.
How many mm is that //// is like 1 mm with all the washers if you use the thin ones
Alec
SP Tuned
Apr 6, 2009
712
Illinois
I think you mean cm, not mm.
