how high is your fuel pressue?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i was just wondering how high is your fuel pressure and how high have you pushed it. as of right now mine is at about 56 psi and i was thinking about pushing it higher cuz i'm still on the 370s.
figgie
Twin Cities, Minnesot-ah
56 psi base?
what fuel pump?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
figgie;1083529 said:
56 psi base?
what fuel pump?
I would like to know that too. you're going to be running into some serious flow limitations if you're running a single pump at that pressure.
I run 30psi base with the vac off, which is low, I just haven't bothered to raise it as I'm lazy.
bhg4life
Frozen
Apr 13, 2007
34
Edmonton
The proper way to measure your baseline fuel pressure is by temporarily removing the vacuum line to the FPR. When you drive the car, you always have the vacuum line on.
mischief7m;1085373 said:
why do some people run vac off and vac on? is there a benefit on either side?
