how far will these stick out?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
Simply as a guess, if it's on a Supra already, It may not stick out too bad.
But like already mentioned, you need the offset. Call the guy.
tyang82
487
Milwaukee
Yeah, I'm still waiting on him. He is at work still, but isn't the wheel fitment different from the mark 4 and mark 3?
High offset they will be sunk not stick out. Might have issues with rubbing on the shock as well.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
The rear wheel on my supra is a common 9.5in +35mm offset wheel, so let's compare it to that:
Mine: 9.5in wheel +35offset = distance from hub mounting to rim: 85.65mm (3.37in), backspacing: 155.65mm (6.13in)
Yours: 10.5in wheel +35offset = distance from hub mounting to rim: 98.35mm (3.87in), backspacing: 168.35mm (6.63in)
Compare it to others who have my wheel specs:
http://www.supramania.com/forums/showthread.php?56843-Wheel-Fitment-amp-Question-Thread
Hope that helps
