how do you diagnose 1Jzgte engine lights?
XxXCHUMP21XxX
10
New Windsor
I'm planning on doing a 1jzgte engine swap in my 1989 supra. I was wondering if you can diagnose future check engine lights with an American code checker? or if i would have to buy one from overseas?
You just jump E1 and Te1 just like with the 7m.
W on the 1jz ecu if for the wire that goes to the check engine light.
te72
Classifieds Moderator
6,626
9
WHYoming
This is the only diagnostic tool we need:
Speaker wire works just as well if you have some lying around. ;)
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
did anyone else have that greyish goop inside the engine diagnostic port? I assumed it was a coating to protect the contacts from corrosion, but when I tried to jump the diagnostic connector, nothing happened. I might try again next time I'm under the hood..
destrux
1,183
10
PA
Yes, lots of grey grease. Corrosion protection.
I hear JDM paper clips work better for flashing the codes out though. :evildeal:
mkiiichip
1,434
WI
Take apart a connector from a junk o2 sensor and make a proper jumper tool. Paper clips are for amateurs.
Have a couple of those in my box at wOrk. Paper works and fits nice in the coin tray for when I'm not at work.
