How do I get rid of....
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Drive over to Kyle's place.
See him drive my old car.
Take notes.
Enjoy.
I honestly dont' know what does or doesn't cause it.
I know my old car didn't do it. The only thing from stock that it had was 0 compression drag shocks in the back.
Dec 3, 2003
6,653
Canada
Yeah let off the gas when it happens :D
Ok..LOL You can get solid bushings for the entire subframe and also have spherical rod end bearings instead of rubber throughtout the suspension parts.
Duane
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well i found out what cause wheels hop these are what i ahve done to slove it
semi solid sub frame bushing's
re infrost track arms
less toe in the rear of the car
none sluppy bushing thou out the rear spetion and such
and to have al less droop as possible int eh rear end cause that is when your alment chnages witch cause it as well
NashMan
Aug 5, 2005
4,940
17
Victoria BC
press fuck that i used my bench vise easy as pie just makes sure they go in stright frist and take some sand paper or die grinder and road the edge's so they go in better and don't for get to add gress nipples
starscream5000 said:
You'll need to get a press to be able to install them correctly. You may be able to find some place that can loan one of those out...
100 more posts to go!
