Mistakes happen—whether it’s a typo in your name or a recent legal name change,
+1 (888) 674-4858 getting your name corrected on your Southwest Airlines reservation is important. A mismatch between
+1 (888) 674-4858 your ID and ticket can prevent you from boarding, so it’s critical to address
+1 (888) 674-4858 the issue quickly. Fortunately, Southwest Airlines makes the process fairly simple.
+1 (888) 674-4858
+1 (888) 674-4858 Southwest Airlines customer service. They are available 24/7 and can guide you through the
+1 (888) 674-4858 process based on your situation. Whether it’s a small spelling error or full
+1 (888) 674-4858 legal name change due to marriage or divorce, they’ll help promptly.
+1 (888) 674-4858
+1 (888) 674-4858 changes. However, the name on the reservation must match exactly with your government-issued
+1 (888) 674-4858 ID. If you changed your name legally, you’ll be asked to provide
+1 (888) 674-4858 legal documentation such as a marriage license or court order.
+1 (888) 674-4858
+1 (888) 674-4858 Waiting until the last minute can cause boarding issues. If your flight is
+1 (888) 674-4858 within 24 hours, call immediately for assistance. Same-day corrections can sometimes be
+1 (888) 674-4858 made but may depend on how severe the name mismatch is.
+1 (888) 674-4858
+1 (888) 674-4858 the reservation, the corrected name, and a copy of any supporting documents
+1 (888) 674-4858 (if required). In most minor corrections, no documents are needed. But
+1 (888) 674-4858 for legal changes, Southwest will require proof before proceeding.
+1 (888) 674-4858
+1 (888) 674-4858 website or mobile app. You’ll need to call customer service directly. If
+1 (888) 674-4858 it’s a same-day flight, going to the airport counter is another
+1 (888) 674-4858 option, though calling first is still faster and more efficient.
+1 (888) 674-4858
+1 (888) 674-4858 and rebook to correct the name, fare differences may apply. Always check
+1 (888) 674-4858 before making any changes. The representative on the phone at
+1 (888) 674-4858 can help explain your options clearly before making adjustments.
+1 (888) 674-4858
+1 (888) 674-4858 via email. Review it carefully to ensure everything is correct. If
+1 (888) 674-4858 any details are still wrong, reach out again immediately. It’s better
+1 (888) 674-4858 to fix it now than risk denied boarding at the airport.
+1 (888) 674-4858
+1 (888) 674-4858.
+1 (888) 674-4858 with all required details.
+1 (888) 674-4858 to process any name changes on your reservation.
+1 (888) 674-4858 to check for fare differences.
+1 (888) 674-4858 for exact requirements.
1. Contact Southwest Customer Service Immediately
The fastest and most reliable way to start a name correction is to call
2. What Name Changes Are Allowed?
Southwest allows minor name corrections (like fixing typos), as well as legal name
3. When to Make the Change
You should make the name change as soon as you discover the error.
4. What You’ll Need for the Change
Be prepared to provide your booking confirmation number, the incorrect name on
5. Can I Change the Name Online?
As of now, Southwest doesn’t offer a full name change feature on their
6. Are There Any Fees?
Southwest generally does not charge fees for name corrections. However, if you cancel
7. Timing and Confirmation
Once your name change is processed, Southwest will send you an updated confirmation
FAQs: Name Change on Southwest Airlines Reservation
1. Can I change the name on my Southwest ticket?
Yes, you can correct minor misspellings or submit a legal name change by calling
2. How long does it take to change a name?
Most corrections are done the same day if you call
3. Can I change the name online through the website?
No, Southwest requires you to call
4. Is there a fee to change my name on the ticket?
Southwest doesn’t charge a fee for corrections, but call
5. What documents are required for a name change?
You may need a marriage certificate, court order, or ID copy. Call
