How did you route Boost Controller Vac. Lines?
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
Well guys I hooked up my boost controller a couple weeks ago and I guess I got the vacuum lines too close to the exhaust piping. Needless to say thank goodness for boost cut:aigo:
How did you guys mount your lines so they are out of the way of everything? Got pictures?
supradaddy0803
1JZ Beater
Jul 25, 2007
46
Athens,TX
Zipties and looms to route them away from all hot spots. Then since I routed my harness under the speedo cable I took all of the wires through the ECU harness hole and back to the mount where I got the controller. Under my hood unless you know what you are looking for you wouldn't see the valve or the vac lines for the boost controller. That's how I fooled this guy in a stock 08 Mustang GT he though my 1JZ was completely stock, well needless to say I laid the smack down at only 13.5 Psi. His money lost.
Kosh
144
Edmonton
Yeah the way he had his lines running one of them ended up resting on the stock y-pipe and it got just a lil hot.
