How are your Sway Bars setup?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I was wondering if anyone has setup their S/T Sway Bars (or other brand) in (what they call) ‘Oversteer’ mode/setting. Basically using the inner holes instead of the outer ones.
If so, how did it handle?
My car still has a bit of understeer using the outer holes and would like to minimize that as much as possible.
Thanks…
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i leav mine in over streer's more
and to get rid of the low speed under streer i added in jic lower bar helped out alot
My whitelines have 3 holes, I'm on the softest setting front and rear...
Need to find my spacers so I can put em on the hardest setting...
CajunKenny
Nov 15, 2007
3,255
Washington
"jic lower bar"? Hmm... I've never heard of it.
Off to do some research... :)
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Poodles;1245390 said:
My whitelines have 3 holes, I'm on the softest setting front and rear...Need to find my spacers so I can put em on the hardest setting...
Mine whitelines are both on medium right now. Not sure if I should change it or not; I would like better handling. It seems to understeer lightly when pushed hard.
CajunKenny
Nov 15, 2007
3,255
Washington
My big concern about putting them on the harder setting is the End Link Tabs holding up. I already broke my passenger side rear one.
My buddy tried to weld it back on; but, it broke again. Argh.......
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
CajunKenny;1246663 said:
My big concern about putting them on the harder setting is the End Link Tabs holding up. I already broke my passenger side rear one. My buddy tried to weld it back on; but, it broke again. Argh.......
True. Luckily I had Randy at BIC weld on his reinforcement tabs. He sells them too I think.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
all this reinfrocment tab adding in a brace bs
i used to put blance on them but frankly it was kinda hard to get the bolt off the end link
so this time around i wleded the tab all the way around instead of the that littel stock weld
guess what it never breaks off and hard as fuck on my car and it's easy to take the end link on and off
so befor you do all that jazz just weld it all the way around it whonte break off in less you\buddy can't weld
this is only bean tested on st bars at full over streer
CajunKenny
Nov 15, 2007
3,255
Washington
Yeah it was a quick fix attempt. He said that it probably wouldn't hold. And it didn't! :)
Isn't the rule of thumb NOT to weld around the diameter of a rod; but, instead weld lengh-wise down the rod. Regarding strength...and/or weakening...
I'm not sure if I explained that right; but, I thought a rod could be weakened if it wasn't welded on to correctly.
Obviously, I'm not a welder... ;)
