how and where do i get an lsd?
Wilcox
157
Great Falls Montana
i have an 86.5 N/A that i know for sure doesnt have an lsd. i know that the lsd came with all turbo models but i dont know where to salavage one, or if aftermarket would be better. so where do i find one, and how do i install it? and all advice or coments about diffs
thanks, wilcox
You post in the want to buy section and look for a used one. OR look for a part out. Or junk yard.
Or spend 1k for a kazz or something and install into your diff housing.
IndigoMKII
2,181
Madison, Virginia
thanks, wilcox
Are you sure you don't have an LSD? What's the axle code? If it's 3 or 5 you got an LSD that's just tired and probably needs new preload shims.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
IndigoMKII;1908628 said:
Are you sure you don't have an LSD? What's the 4th to last number of your vin? If it's 3 or 5 you got an LSD that's just tired and probably needs new preload shims.
I have a 90 turbo and the 4th to last number is 9.....
Edit
North American Differential Codes:
G284 = 4.30:1 4-pinion 8.0" pre-89 N/A Diff (no-LSD, USA Only)
G282 = 4.30:1 2-pinion 8.0" 89+ N/A Diff (no-LSD, USA Only)
G285 = 4.30:1 4-pinion 8.0" N/A Diff (with-LSD)
G315 = 3.91:1 4-pinion 8.0" pre-89 Turbo Diff (with-LSD)
G305 = 3.73:1 4-pinion 8.0" 89+ Turbo Diff (with-LSD)
Sent from my DROID RAZR using Tapatalk 2
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I'm not sure if the 86.5 came with the optional sport package or not. Non sport package models IIRC came without TEMS and had a 4.30 open diff. The sport package models came with TEMS and a 4.30 LSD. My 88 was a N/A sport package with the LSD.
zby67
173
Texas
Moy all sport packages come with Tems and an LSD??? if so then i do have Tems on my 87 (if i have an LSD i never put the additive in when i changed the diff oil...)
90 turbo you should have an LSD JDMfreak... unless were missing something...
well if this is true i had hopes but almost none since its an N/A auto. my 4th to last # is 2 my 5th is a 3 lol
zby67
173
Texas
hvyman;1908657 said:
There will be a lsd sticker on the diff cover.
well i didnt see one. is it possible it rubbed off with age? is there another way with out braking it open?
I havnt seen one fall off yet.
And no. You can count the turns of the wheels but if its a 4.30 you wont be able to tell from that. Only if someone swapped a turbo diff in.
The sport packages came with almost every option. So if you have tems doesnt mean its a sport package.
Wilcox
157
Great Falls Montana
I do have an tems switch on ny center consol. I will check my vin and know for sure if i fo have an lsd. If my diff shims are worn out it would act as a non lsd, correct?
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Look at the vehicle data tag for the A/T (Axle/Transmission) code. It should be G28x/W58 or G28x/A340 for an auto.
For what it's worth, Canadian spec Mk3 NAs were all sold with the G285 (4.300:1 LSD) axles, so there should be a supply of them here.
SC61 MK3
316
FL
Jack the rear of the car up and spin one wheel by hand, lsd will spin the other with it
Maple191
317
Toronto
I have a an 89 turbo i know its a LSD and the sticker has fallen off. Almost all my customers at the shop with LSD's are missing the sticker. They just dont stick.
IndigoMKII
2,181
Madison, Virginia
Wilcox;1908787 said:
ya my vin tag says g285, so i know i have a lsd, but it acts as if it is a non lsd. so all i have to do is replace the shims right?
There's a rebuild for doing the shims somewhere, I'll see if I can find it.
Wilcox
157
Great Falls Montana
how does a lsd affect a drift? cause i can do great dry payvment drifts if i clutch kick, but when i go to do dry payvment j turns i fail cause only one tire breaks loose.
