Houston guys, I need to borrow a 7MGTE ECU
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
The one that came with the car when i opened up the glove compartment to get to the ECU was a junkyard unit from an 87 M/T.. it was marked as a A/T computer (dumbasses). Im not sure if the A/T and M/T computers are the same though..
As of now, im trying to see if its the ECU thats not giving me spark. Then, ill go and check the ignitor and coilpacks.
Scot
Enough is Never Enough
Jan 9, 2008
185
Houston, TX
there are a couple of fuses you need to check in drivers side kick panel fuse panel. One say ignition and the other says ECU ign.... Also check the big fuse under the hood.... maybe a 30 amp??? It's square....
