Now that I have figured out how to hook my AVCR boost controller to my HKS external wastegate(thanks to Chevyeater and a couple others on Supraforums), I still can't figure out why I'm overboosting. I decided to eliminate my boost controller and just route the vacuum line from the turbo compressor port straight to the side port of the wastegate. I figured this would regulate boost to the standard spring pressure(which is 16psi according to the former owner). Unfortunantly I can't hear the wastegate open until way past 20psi. Does anyone have any other advise on how to check to see if the wastegate is working properly? Thanks..
