HKs TUrbo Timer Wires???
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
I just Bought a type 1 HKs Turbo Time! Got everything connected but the [brown] & [Blue] that come out of the Turbo timer
I know it connects to the ECU. There was a thread on here, how to do it but the guy had a GREY Connectors for the ECU and he spliced a solid red and a solid Pink. I have the YELLOW Connectors which wires due i splice? is it the same SOLID PInk & RED?
---------- Post added at 11:19 AM ---------- Previous post was at 11:05 AM ----------
anyone?
isnms
United States of America
Oklahoma
i80.photobucket.com
Here is what I have. HTH
Don't connect the blue wire if you want the security system to arm when you lock up.
May not be your TT. I don't show a brown wire.
noel
Uchiha Member
May 5, 2008
512
so if i connect the blue wire the alarm wont work when i lock the door with my key? whats the piont of that of course i want the alarm to kick in after i lock the door while the TImer is counting down
---------- Post added at 11:36 AM ---------- Previous post was at 11:31 AM ----------
http://www.supramania.com/forums/showthread.php?97678-GUIDE-Fitting-a-turbo-timer that is the link where he connected the wires there different on mine
noel
Uchiha Member
May 5, 2008
512
thoses are the wires im talking about [blue/brown] and that is the TUrbo Timer i bought ....where do thoses 2 wires go? u can see the YELLOW Connecter behind it
isnms
Oklahoma
i80.photobucket.com
isnms
Oklahoma
i80.photobucket.com
Then find out which one of those wires in that big square connector connects to the ACC on ignition switch.
What ever color it is, you don't want to connect ACC to TT if you want security system to arm.
