HKS T04e 67 trim ...
Supra-Man18
357
miami
Thinking about purchasing it from a friend to replace my blown twins... it has a .96 back housing but im not sure if the 1j can handle that efficiently.. anyone here have feedback from a .96 a/r ?
thesupragod
183
Mount Vernon, Ohio
seems a bit big for 2.5 liters of displacement.. i dunno though, do you have a flow map for the turbo? I'll guess that you wont start building boost until probably 4700-5200 unless you have a tuning device with an anti-lag setting...
Just my $.02
albert74
111
Florida
You will be alright with a .96 ar on that turbo. Lag is overrated. My friend had a t04s down here on a 1jz with a stock head and block with a .68 and that turbo would spool quick but it would loose steam on the top end. A .96 ar changed that, and he only lost about 500 rpm spool time on a high gear accelerator punch. If he downshifted to a lower gear, lag would be almost non existent.
Supra-Man18
357
miami
Only 500rpm ? Seems Decent... How much boost was he running ?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
are you sure that the turbo spools only 500 rpms later? i would imagine it would spool much later than that?
albert74
111
Florida
17 psi, stock intake mani, blitz ecu and 31x12x3 IC. I would think the blitz ecu attributed to earlier spoolup due to more aggressive mapping, but a 1jz will spin a .96 on a t04e fairly well.
jblaze
"Always the underdog"
Apr 14, 2006
51
Baltimore, Md
I would also like to comment on the "dying up top" thing concerning a .68AR... I have a friend that has a .68 on his Supra and he still trapped at 136 mph on his 67mm WITH A CRAPPY START AND CRAPPY TIRES. So to pick up almost 140 mph:icon_evil in the 1/4mi def is proof that it was not dying up top. This is a MKIV, but still... he does not have the rpm range that the 1j does. So don't believe the hype. You probably would have a little more up top with the larger AR but that doesn't mean the smaller AR is dying off... also look at your DP and exhaust to help free up any restrictiveness. hth
Twin 1jz
65
San Juan
Are you talking about a 67mm compressor wheel turbo? I haven't seen a 67 trim t04e turbo. Check the specs on the turbo. A to4s will spool fairly good with a .96 a/r but with a 67mm compressor it will not.
rakkasan
Currahee!!
Fort Campbell, KY
I run a .58, and it doesn't lose steam. I have made 500+ rwhp, with a torque curve that flattened out around 4700rpm all the way to 8000rpm. Maybe you need to revisit your statement.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
My turbo is a .68 a/r and I dyno'd it with a blitz ecu rev it out to 8k and it never died.....
So In my opinion that too is a myth.
you want proof I got the sheet to prove it!
OH and another thing. Lag is only really a problem in 1st gear.
