hks super dragger
MKIIISupraGuy
639
Lousy-ana
its very good. I could listen to that exhaust note ALL day. My bro has it in his MKIV. Here is a vid if ya wanna real good idea on what it sounds like...
btw he got his setup for 680 I believe it was....
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
EXCELLENT PIPE!;)
Very quiet... but fully capable and very mature in sound. I am very impressed with the construction, performance and "BRUMBLE" that this quality piece makes!
(If you WANT an obnoxiously noisy raw exhaust note, this is NOT the pipe for you!:naughty:)
Here's the most recent shots of it... (in for some body and paint work) but the rod welded ONTO the muffler is NOT a part of the HKS kit. My muffler guy did that to stabilize mine even though it "mars" the perfect can a bit. Function over form.;)
http://www.supramania.com/forums/showthread.php?t=50428
^^^ There's the original INSTALL thread. It will look better with the single aluminum drive shaft and the repaired bumper and painted undercarriage and fuel cell! I'll have to clean the pipe up again once it's back from the shop!
-crisp
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I'm running the HKS Super Dragger setup and absolutely love it!
Like Crisp said....It's pretty quite until you don't want it to be. Even then, it does not resonate to/thru the car. It does a great job of projecting/keeping the sound behind you.
Let's not forget to mention that it looks very sexy!
S.A. supra
2,405
Buda, Texas
Great exhaust. I've had mine for two years and they holdup very well. Nice and quite at idle with a nice rumble at wot. I had it on my 7mgte and swapped it to my 1jzgte. great exhaust you won't be disappointed.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I had a dragger 6 yearsago on my first supra, and it was very melow as said above. It sounded excellent, and was easily the nicest sound while driving I've heard. At idle, I remember questioning if my car was even on. You could barely make out a faint grumble, but when you give it some gas it does wake up, but keeps it's composure the whole time.
eric
crisp
May 25, 2007
1,785
Ohio
aznboik1mva;1440809 said:
how good is this exaust with a test pipe and hks downpipe?
I found a clip with some decent audio of the pipe at the beginning... (after that, "other" noises begin to overwhelm the exhaust...;))
PS: This footage is with DP and "test pipe". I forget if I shot it WITH the HKS DP or after I changed to the Titan Motorsports, which is less restrictive and eliminates the stock elbow.
http://s100.photobucket.com/albums/m26/crispone/crispvids/?action=view&current=R0019986.flv
-crisp
goliath
Fears no evil!
Lancaster, PA.
:withstupi Mine is on a 7M, love it!:love:
BrandonW
1,300
N.J.
quiet and deep rumble on my 7m-gte with a ddp test pipe with a cat on it sounded even more quiet
supra_guy
29
Illinois
Does it really? Its 750 where I got it from...OOOO right "aznboik1mva" it comes with an hks downpipe thats why its 600 haha. so Downpipe + hks super dragger
Mine has a louder growl because I cut the 1st muffler and welded a straight pipe. (the exhaust was just way too quiet with a muffler, resonator, and then the hks super dragger can muffler.
emiliorescigno
1,199
Woodbury, MN
You should also note - the HKS downpipe is pretty bad. It hangs low and still uses the restrictive stock turbo elbow. You should get the exhaust and test pipe, but stick to a downpipe that includes a 3" elbow. (Such as a BIC downpipe)
