HKS Fuel Cut Defender on Epay
7M4EVR
695
fah, fah away
Looks like he has those by looking at his sig...also looks like hes been around since 06 so you would think he knows that fuel cut is there for a reason?
NADude98
50
Terre Haute, IN
LOL, I just want to run 15-18psi with out hitting the occasional fuel cut, which isn't good for the engine either. I have my boost controller set where I am running 15 but in third gear when the turbo spools it must be spiking a little above and I get fuel cut. The thing is it doesn't happen all the time. I guess my next question is how much boost should I be able to run safely with the setup I have? Also my goal is 20psi at some point!
super51fan
497
Indianapolis
I don 't know how come the MKIII crowd is so against FCD. On one hand they talk about the over rich safe factory fuel tuning. Then on the other how the FCD kills engines. Yes you can be stupid with anything. The MKIV crowd suggest the FCD for BPU setup. With your list of mods I think it is a good idea. Btw the black car in sig. page has ran one since 1992.
super51fan
497
Indianapolis
I do agree with new boost controller is a good idea. The airflow with turbo upgrade could be around 15 -16 psi of boost to hit fuel cut. Btw you are about at the top of the mark before standalone.
I do feel the HKS FCd will allow him to achieve his goals. And 18 to 20 psi will be close to maxing out injectors.
Dirgle
Conjurer of Boost
Pauma Valley, CA
The reason is, that it is a very destructive tuning item when used in an uneducated or improper way, which more often than not it is. There were a large number of people that did kill their engine in the early days. Those pages existed on the pre-pre-crash forums and mailing lists. The HKS FCD was intended to be used in concert with several other supporting HKS electronics, it deviates the signal from the AFM by a set percentage across the entire operating range. So while there may be plenty of extra fuel to get past fuel cut at WOT, you can encounter other driving situations where the ECU is searching for a more stoichiometric option and the deviated AFM signal can create a dangerously lean condition. So while people may think they have plenty of room to push the envelope when checking AFR's at WOT, they have run out of room in other areas that they are not paying attention to.
And just because you have successfully used the FCD for a long time doesn't automatically mean it is a good idea, primarily due to the inherent risks in using one. To use an analogy, If you hand the average person a chainsaw, and send him into the woods to start cutting down trees, there is a very high probability that he is not going to come back alive. If you give that person some knowledge on the proper way to cut the trees down, the possibility that the person comes back alive improves greatly, but it does not change the inherent risk that person will face cutting down trees. That risk is there regardless. That risk is the main reason we don't recommend using the FCD. Especially when you take into consideration the likelihood of what is becoming the typical MKIII owners probability to cut corners, or not heed warnings when setting up the FCD. It's more productive to dissuade the use of the device to the majority. Those that are left are going to use it regardless of what it said, but hopefully they will do so fully understanding the risks.
Lastly, the MKIV community do not suggest using the HKS FCD for BPU setups. The typically recommended device is the Greddy BCC. It clamps the signal at a set level, unlike signal deviation that the HKS employs, so that the various ECU controls, such as sequential turbo operation are not altered.
