HKS BOV install???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
I have the HKS (style) BOV from drift motion, but how do i install it???
I have the flange pipe also....
PLEASE HELP
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
What is so crazy???
I just dont understand how the mount it on the pipe with those "c" clip things!!!
Then what vaccum line do you tap into???
Nothing Crazy about it!!!:nono:
EvoLuTioN
no-JZ Your Mom!
Mar 10, 2006
508
Bed
it's a pain in the ass, i hate those c-clamps, i just took a pair of pliers with a really fine point and had the BOV in the mount and then just push down, it took me a million tries, pain in the ass, stupid and dumbest design ever, and I just had it tapped from my intake manifold
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
the vac line is the same vac line for your stock turbo Bypass valve that comes from near the intake manifold
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Im installing it on my buddy's Tiburon that has been turbo kited, so there is no factory BOV line... Which one should i tap into???
The C clamp dont make sence to me!!!
How do they work???
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
You need some needle nose pliers that are fine tipped and pre bent to get a c-clip installed easily. To further elaborate, you will need to tee in the vacuum into a vacuum line directly BEHIND the throttle body plate. Installe the BOV as close as possible to the throttle body if you can.
1jzMoe
263
Vilseck, Germany, Germany
you will want the snap ring the ones with the 90 degree bend at the end, those are the ones you want with the hks bov, i didnt have one with the 90 degree bend and that how i scratched my bov up
