HKS Alphabet Soup Wiring
schmuckingham
56
OHIOWN
I have a PFC FCON for my 1g-GTE along with a GCC. I have the correct harness for my engine to use the FCON but I want to eliminate the AFM with a VPC. Can the VPC be hard wired into the harness that comes with the FCON? These Toyotas are new to me so I figured I would ask and finding the harness for my engine was hard enough for the FCON.
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
Of coarse it can, I used to run the same setup. If it's a 3rd gen engine/ECU you'll want a TV04 and TP15 patch harnesses, or you can hard wire it if you wish.
They aren't difficult to find considering these are 20+ year old electronics, you just have to know where to look.
Edit:
Also running a VF001B VPC and F-CON E102 chips, hope that helps someone.
